Quickstart Debian / Ubuntu
This tutorial describes the steps needed to setup ChirpStack on a single machine. Recommended distributions are:
- Ubuntu 22.04 LTS
- Debian 11 (bullseye)
Note before you start
The purpose of this tutorial is to help you getting started. Topics like HA setup, database backups, setting up firewall rules are beyond the scope of this tutorial.
Install requirements
The following command installs the ChirpStack requirements using the apt
package manager:
sudo apt install \
mosquitto \
mosquitto-clients \
redis-server \
redis-tools \
postgresql
PostgreSQL setup
To enter the command line utility for PostgreSQL:
sudo -u postgres psql
Inside this prompt, execute the following queries to setup the ChirpStack database. It is recommended to change the usernames and passwords.
-- create role for authentication
create role chirpstack with login password 'chirpstack';
-- create database
create database chirpstack with owner chirpstack;
-- change to chirpstack database
\c chirpstack
-- create pg_trgm extension
create extension pg_trgm;
-- exit psql
\q
Setup software repository
ChirpStack provides a Debian / Ubuntu repository which can be used to install
the latest ChirpStack version. First make sure that both dirmngr
and
apt-transport-https
are installed:
sudo apt install apt-transport-https dirmngr
Set up the key for the ChirpStack repository:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 1CE2AFD36DBCCA00
Add the repository to the repository list:
sudo echo "deb https://artifacts.chirpstack.io/packages/4.x/deb stable main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Update the apt package cache:
sudo apt update
Install ChirpStack Gateway Bridge
Note: If you intend to install the ChirpStack Gateway Bridge only on gateway(s) themselves, you can skip this step.
Install the package using apt
sudo apt install chirpstack-gateway-bridge
Configuration
The configuration file is located at /etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml
Please update the [integration.mqtt]
section to match the region prefix for
the region that applies to this ChirpStack Gateway Bridge instance.
Example for EU868:
[integration.mqtt]
event_topic_template="eu868/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
command_topic_template="eu868/gateway/{{ .GatewayID }}/command/#"
You can find the region configurations that are included by default here: https://github.com/chirpstack/chirpstack/tree/master/chirpstack/configuration.
Starting
Start the ChirpStack Gateway Bridge service:
# start chirpstack-gateway-bridge
sudo systemctl start chirpstack-gateway-bridge
# start chirpstack-gateway-bridge on boot
sudo systemctl enable chirpstack-gateway-bridge
Install ChirpStack
Install the package using apt:
Configuration
The configuration files are located at /etc/chirpstack
. You will find one
global configuration file called chirpstack.toml
and various region
configuration files.
Starting
Start the ChirpStack service:
# start chirpstack
# start chirpstack on boot
Print the ChirpStack log-output:
sudo journalctl -f -n 100 -u chirpstack
